Taking on water
galaxian
O.k... I just bought my first bought, a fixer upper. The drain plug leaked bad. I replaced it with a new one. Took the boat out over the weekend and had it sit in the water for several hours. No leaking... I then took the boat out around the lake a couple of times... I ended up with a little bit of water in the hull. I mean, maybe a half gallon... I emptied it out that night, left the boat in the water, took it out again the next day, the same thing... Is there a less complicated and inexpensive place to start the fix. Thanks....
HT32BSX115
Re: Taking on water
Howdy,
Without knowing what you have ......I have no idea where to begin...
http://forums.iboats.com/showthread.php?t=220416
galaxian
Re: Taking on water
LOL... I tried to add that after the fact, I guess it didn't update fast enough... It's a 1988 21' Donzi, OMC 350, 5.7L
Re: Taking on water
Ayuh,.... I would begin by posting only 1 Thread about your Problem,...
I posted in This 1...
