Taking the motor out to (at least) replace flywheel
robbyr1
I just keep having good luck with this boat! I tried to take it out the other day and got the noise described here: http://forums.iboats.com/showthread.php?t=414873
Then it starting just a "winding noise". So, I took the starter off and found that I had ground down a bunch of teeth on the flywheel. So now I'm taking the motor out to at least replace the flywheel and, hopefully, what caused it.
I don't know if it was hydro-lock, mis-aligned starter, bent shaft or what. Do you guys have any ideas? How about some tips on what to do/not to do to take the motor out? Thanks!
robbyr1
Re: Taking the motor out to (at least) replace flywheel
Oops, sorry...should have posted this in the engine forum. I'll post it there. Mods, please delete this.
rockyrude
You will get tons of help once we know what it is you are replacing a flywheel on.
a70eliminator
The link he posted provides the details.
