Hi all
ill keep it brief and hoping the collective might think of something I haven’t.
Merc Alpha 1 drive and 5.0 Mpi
occasionaly last year I suspected the boat was taking on water. I’d run the bilge pump each visit to check before lifting the hatch for the usual pre run checks. Sometimes the pump could run for a good 20 secs and likely pump out a good 4/5/6 gallons. Sometimes just a spurt and sometimes nothing and as I left it.
It doesnt seem to take any water in when I’m out in it and Mostly up on the plane. So I’m thinking it’s coming in when the boat is at rest and sitting deep in the water. It sits particularly deep at rest with the water line being over the top of the drive and almost all of the transom shield too.
I originally thought the bellows, but they are in great shape and as new. Also tried leaving the drive steered to the extreme left (port) to extend the bellows fully. Then tried leaving to the right. Centre and everything in between. There seems no rhyme or reason to the ingress of water and when it happens.
Now its its worth mentioning that the boat is a bow rider and is in Scotland. It rains a lot and I originally put it down to rain getting in forward of the windscreen where the bow cover doesn’t seal. It does come in here for sure..but this happens when it hasn’t been raining too.
Other thoughts were it must be the steering arm section or the transom seal it’s self...but why doesn’t it leak all the time.
The leaking stopped towards the end of the season...but having had the boat in the water for a week to check before I do all the servicing and to see if I need to pull the drive again...it’s started leaking again, in the same random way. One day next to notnhing and the next a few gallons. I also worry that perhaps the days there was next to nothing coming out...perhaps the float switch on the pump has already pumped it out just before. Perhaps it’s been triggered all the time when I’m not there ?
any ideas on what else ? I’ve checked all round the engine at the sides but haven’t yet squeezed down for a long term look. Where would the obvious place be to look. It’s not a nice place to get to or be for any length of time as you can imagine. When the drive was pulled end of last year...no sign of water in the bellows
