Tan/blue cable needed for the low oil alarm circuit extension
dandreye
Hi All,
I need to extend my Commander 2000 wiring harness to the dashboard as its standard 5-wire dashboard harness is missing. Where can I get about 5ft (1.5m) of TAN/BLUE cable (tan with a light-blue stripe), ideally of the same AWG to extend Mercury low oil / powerhead overheat circuit? Found all other colour coded cables except for this one and don't want to change the colour coding.
Many thanks in anticipation,
Dmitriy
Fun Times
Re: Tan/blue cable needed for the low oil alarm circuit extension
Item #, 14 86044A11 CABLE ASSEMBLY, (20.00 Feet) Tan/Blue Wire With One Ring and One Spade (20 Inch) Not Available
Item # 14, 86044A4 CABLE ASSEMBLY, (36 Inches ) Tan/Blue (36 Inch) Not Available
Item # 14, 13760A6 WIRE ASSEMBLY (42 Inch with insulator) Not Available
http://www.shortsmarineparts.com/pa...it(86047A18)/09-002-898116-100/COMMON13218046
But you may be able to order it from Seaway Marine in seattle washington @ 800-332-0803.
http://www.seawaymarine.com/
Good luck.:)
oldman570
A search of wire manufactures on the internet should get you a list of manufactures that just might have the wire you need. Otherwise a search of the salvage yards listed in the TOP SECRET sticky here on Iboats might have what you need.
Oldman570
dandreye
Fun Times:
oldman570:
Thank you - will try.
serico
It's possible that a Merc dealer might have a junk engine lying around, from which you could salvage some wire. Other than that, label a generic wire at both ends "blue/tan (alarm)" and that ought to tell people what they need to know.
