my tandem axle trailer pops and bangs alot, it has ever since I pulled thru my yard and down a very steep enbankment allowing one axle of hte trailer to be suspended in the air.<br /><br />well now the triangle shackle pivot, is angled to one side, one axle shackle goes down and the other up?<br /><br />which is the correct orientation and how to fix? ( ive got the boat off right now so I figure Ill fix it while its easier to jack up teh trailer, should I lift all 4 tires to remove load and remove the bolt that attatches the pivot to the frame and then flip it over and remount?<br /><br />thanks in advance!
