Tank replacement
After my second day of boating on my recently purchased Century 2300 CC I step on my boat to discover a bilge full of gas. After coming to the conclusion that there is a leak in the bottom of my 99 gal. aluminum tank, I realized that there is no hatch in my deck to remove the tank. I am not going to do the fiberglass repair but I was hoping I could save myself some money on the repair by getting the layout of the hull/stringers. That way I could cut the deck, remove the tank, install the new tank, and then bring the boat to a fiberglass repair guy for him to finish the deck. Does anyone have a detail of the hull or any other smart advice?
Cadwelder
Re: Tank replacement
I wouldn't think you'd save to much there, if your repair guy is going to cut it all out to replace/repair the deck...the tank will then be exposed. I can't see him charging too much more to install the new tank (that you supply) while he's in there. Be worth asking him to see.
Silverbullet555
Before assuming it is the tank, I would have it pressure tested to determine the cause first. It might be the issue, but it might not be.
