As I move through the carb>powerhead>magneto>lower unit on my two vintage (late 50s) OMCs I've been finding several bolts/threads in need of TLC: gunked up, rough, and now a lower drain plug looks cross-threaded...
On the 'cheap' - considering this and an old Lawnboy are the extent of my wrenching and the primary need here is to just clean up threads, not cut new - a couple options appear to be:
- ~30pc SAE tap & die set, though it probably doesn't have all I need, and other sizes I don't
- Buy individual tap/die as needed as bolts are pulled and sized, but I don't know I have the patience/time to go this route
- Try the youtube method of buying a new bolt to fit the various thread, grind two slots in its threaded end, and use it to ream out the hole. Seems to good to be true...
It'd be of great help if the Johnson service manual had a quick reference to bolt sizes, but alas I see none.
What are other folks doing?
-Brent
-Brent
