76SeaRay
- Aug 24, 2017
- 1,071
I read through the sticky on the TB IV and TB V but didn't find the answers to these questions. I have a TB V.
Coil -- What coil is recommended for use with the TB V?
ICM Mounting -- Should the TB V ICM have heatsink compound between it and the mounting bracket used to secure it to the Port Exh elbow?
ICM Mounting Plate to Port Exh elbow -- There are phenolic washers called out between the mounting plate and the exhaust elbow. Are these for heat insulation? They are only about 0.063 inches thick so if for heat insulation is there a better choice (ie, thicker, different material, etc.)?
