Re: TBI
Dlelsea.. The look of the injectors spraying too much fuel is normal... I know it looks like alot of fuel is comming out, but it
usually is just the way the injectors make it look because of their spray pattern...<br /><br />Your problem could be caused by anything form a dirty fuel system or filter, a bad sensor, or just the need of a good basic tune up (plugs, cap, rotor, ect.)... A little fuel injector cleaner in the gas tank could'nt hurt either...<br /><br />I would begin by checking the basics like making sure the ignition timing is correct, adequate fuel supply, and using a service manual and a code scanner; to check for trouble codes...
http://216.230.203.183/marine/marine.htm The CodeMate <br />EFI Code Reader, Part #94008 listed on the link, would be adequate to help you diagnose any problems you may have with any sensors...<br /><br />P.S. Just like a car with fuel injection, Don't "pump the throttle" when you try to start it.. With EFI/TBI, that will just make matters worse...
