Re: TD-20 5hp fuel mix
Howdy, Cbras. The original recommended mix for your TD-20 was 24:1, or 1 quart of oil to a six gallon tank.<br /><br />The knob sticking up on top of the carb is the high speed mixture adjustment. The plunger behind it is a primer pump (there is no choke). <br /><br />The low speed circuit is not in the carburetor, but on the side of the engine. It feeds a rotary valve that is seperate from the reed valve system. The low speed mixture is adjusted by the needle that sticks down at an angle from the rotary valve intake.<br /><br />My manual shows the TD-20 with a recoil starter. Is yours missing or does it appear to have been built to use a wrap-rope?<br /><br />Red sky at night. . . <br />JB
