Re: Teak Refinishing
Teak as old as yours can be varnished successfully if it is coated on all sides.. although it is true that it has a lot of oil in it when new. I use epoxy with a sun bloc mixed in, I remove the wood, sand it down to clean wood, and coat it on all sides with 5-6 coats. then I put another 5-6 coats of varnish on top, sanding in between coats. the wood is beautiful and will last a very long time if you keep varnishing it twice a year..I have done this to many boats and it has worked very well, It is a lot of work......." how can i tell if it is teak" ,Teak has a very unique look to it, if it is left to the elements, it will turn a dirty grey color, if it has teak oil on it it will be a cloudy golden brown, if it is varnished, it will be a bright golden brown with a very beautiful grain.
