Ted Williams 7.5 HP Help
markdavis
I was wondering if anyone could help with some information on a Ted Williams 7.5 HP engine I picked up. The serial number is #1323-11, and the engine was made by Tecumseh. I have the following questions:<br /><br />1) Year?;<br />2) Gas/Oil ratio?;<br />3) What spark plug does it take?; <br />4) I think that the engine is air-cooled, and that the lower unit is water-cooled with an impeller. Is this correct? What size impeller? and;<br />5) Can you run the motor with a flushing device, or does it need to be in a tank??<br /><br />Thanks for the help!!
EZLoader
Re: Ted Williams 7.5 HP Help
Hi River,<br />I've been posting this information to all Sears posters. Did you read and find your answer on any of their same requests in this forum? Hope this helps.<br /><br /><br />Links to History, Manuals and Parts:<br /><br /> http://www.geocities.com/scottmc9hp/photogallery13.html <br /><br /> http://www.hypermax.com/wwwboard/messages/6615.html <br /><br /> http://www.manddsmallengine.com/tecumseh/740047.html <br /><br /> http://www.repairmanual.net/marine/53/475 <br /><br />For Eska parts:<br /> http://www.certifiedpartscorp.com/ <br />(Do a general parts search for "Eska")
markdavis
Thanks!! I did find some information, but I wasn't sure how dependent it was on the model, etc. I will be sure to check out the links. Thanks again.
