Ted Williams 7.5 no spark
tiger 650
Made by Sears& Roebuck<br />Chassis # 217 58 5870<br /> serial 5-b-196955<br />This has electronic ignition. The coil is good. Who can sell me the module?
mellowyellow
Re: Ted Williams 7.5 no spark
try local mower/small engine repair shop.<br />it's a tecumsah powerhead.
dperkins4
Even tho it doesn't have points it still generates spark power from the flywheel & magnet passing by the coil. Maybe the flywheel has a layer of rust on it keeping it from generating the spark ? Pull it , check it, sand the rust off of it and the coil. <br /><br />Sometimes too,,, flywheels will lose or weaken their magnetism which may prevent it from creating the necessary electronic field. <br /><br />I have one of those old motors laying under my storage building if you'd like I can check the numbers on it to verify part cross over and we may can work a deal. If I'm not mistaken, the one I have is called a 7.5 but looks like a 5hp Techumshe 2 stroke.<br /><br />Let me know.... perk_dp@hotmail.com
tsb64748
I would like to know if you found the module?Iam also looking for one let me know
szepj1
I am also looking for a coil and ignition module. Y'all wanna keep me in the loop? (I'll be back!)
