Teeing in a kicker motor
drice379
I want to tee in a nissan kicker with a 5/16 fuel line into the line on my main motor. The main motor is a 90hp yamaha 2 stroke 2003. Does it also have a 5/16 line or is it a 3/8?
99yam40
Re: Teeing in a kicker motor
something to think about when teeing in , is that the fuel pump on both motors will be sucking on the line and if you do not block the other one off with a valve it can suck air through the other line-pump-carb if you are not carefull
drice379
I'm going to use a primer bulb on both lines for the check valves
