TeeNee trailer
kfabry
I have a TeeNee trailer, single axle, that I'd like to identify. The only tag on it is the factory tag that gives the serial # and info about TeeNee factory stuff. The serial # is 64381. There is currently a 16'-3" wood boat sitting on it which looks like it was ordered or bought to fit this boat. Is the serial # enough to get the year built and model #? Thanks for any help on this.
sphelps
Hmmmm , I don’t know the number system but my Tee Nee has the number 75496 and the registration says it’s a 1958 ..
‘But it’s also registered as homemade .. I’m not sure if it’s correct really .. I haven’t done the research yet ..
JimS123
IMHO, TeeNee made one of the best trailers there ever was. My last one was a 1984. Unfortunately, they went out of business quite awhile ago, thus finding data is going to be hard. Look at the link below - that should give you some insight, but not as to the year.
"Home made" trailers often get that way because the PO lost the paperwork. Some times the SN may be correct if that is what is stamped on the frame. Based on Post #2 my guess is that yours is prior to 1958.
http://www.fiberglassics.com/library/index.php?title=Tee_Nee
