My steering froze up for the most part over the weekend and looks like it is time for replacement. I have a 17'5" Aquasport with a 88 johnson outboard. I was able to remove the steering wheel, helm, and cable. The cable connection at the engine was simple once I lifted the engine off the transom. I'm ready to put everything back together and picked up a Teleflex steering kit with the No Feed Back rotary helm. Problem is that I got the 4.2 instead of the Safe-T II. The 4.2 is made for "up to V6" engines and has a slower ratio - 4.2 turns lock to lock. The Safe-T II is made for "V4s and V6s up to 50 mph" (I top out at 40 mph); it has a ratio of 3 turns lock to lock. Both are the No Feed Back system.
I realize it will take more steering wheel rotation to achieve the same change in boat direction, but is this an issue? It seems like it would be less responsive, but would tend to wander less on center. An opinions?
