danhend
- Oct 2, 2008
- 21
I have a Teleflex Saftyt QC 15' Sterering system that was very stiff. Following the advice on this board, I detached it from the motor, and the motor moves freely. I am now looking to replace the steering cable. The way my motor is mounted, I am unable to pull the cable through the existing hole in the motor well. The nut that attaches the cable is too large. Is there a way to detach the cable from the rod? Or do I have to moce the motor in ordewr to line up the cable and the hole? I am loathe to attempt to move the motor.
I have also seen posts refering to Rotory and hydrolic systems. What is the difference, and should thart be something I am looking to use instead?
BTW it is a 18' bayliner with a M90A Tohatsu 2 stroke.
