Milksnake12
- Aug 9, 2020
- 10
I'm trying to get an old '73 Fiberform back in the water. I discovered the steering was very tight and narrowed it down to the telescoping arm the moves the motor back and forth. When I unscrew the bolt on the starboard side of the arm and turn the wheel, a rod goes in and out smoothly. But when put the bolt back on that forces the cable to drive the other end out of the tube and actually move the motor, it is very tight (disconnected from motor, the motor turns easily by hand). I removed the rubber end cap and there was a plastic bushing in there that cracked apart. My questions are is this telescoping part removable from the cable and if so, how can I get it off (with the hopes of identifying and fixing the issue if possible)? Or is this an issue that would require the whole steering system to be replaced?
