Tell me about your anchor ball
Beefer
So I have an anchor ball set up, and I'm debating whether to use 3' of line between the ball and the anchor ring. They say with out the added line, there is less chance of fouling your prop. How is yours set up?
Also, where do you store your anchor ball? Mine is too big for the anchor locker, and I'm thinking of clipping it onto the bowrail stanchion, and letting it sit on the deck (walk around, so it will stay 'inside' the boat).
2ndtry
Re: Tell me about your anchor ball
I've heard about truck nutz, but giving your anchor balls is a bit ridiculous :)
DuckHunterJon
I'm stumped - what is an anchor ball? At first I was thinking a mooring float, but then you asked where to store it. Looks like another google action item for me.
shrew
Is this just a float used to identify the location of your anchor? IS this device also used for possbly retrieving a fouled anchor? If this is the case, then the length of line would be dictated by the depth of the water, accounting for tides (if applicable). Personally, I wouldn't use one. There is too high a chance that either you or another boat will foul the line.
Beefer
So none of you lake boaters use an anchor ball, huh?
Fireman431
SS ring, 1' of rope/line, anchor ball.
The last thing you want is more line than necessary under the boat. The shorter the line between the ring and ball means that the anchor line is closer to the surface, therefore less likely to foul a prop.
cyclops2
Banned
A true ?? anchor ball is a vertical line going down to a 2000 pound or heavier concrete block permanantly at 1 location. Home port / marina bay. The anchor blocks are all usually to heavy to drag in a 150 mph breeze. The ring at the top of the down line is MASSIVE. To take all that constant metal to metal yanks during high winds. The ball float is clipped on to the ring. Your bow anchor line is linked or knotted to the ring when anchoring.
Most of us remove the anchor ball after the bow winch / windlass has lifted the ball a little. Scope the line.
Mixing sail & power boats closely on a anchorage is bad if there is a water current. They swing at different rates to the wind changes. ESPECIALLY very light winds. BUMP
Seen it happen all day right in front of the marina anchorage. Year after year.
Beefer
Uhh.... that's NOT an anchor ball.... that's a permanent mooring you're describing.
dingbat
My uncle used one religiously when he fished commercially out of Jupiter Inlet. He was 67 and swore by it.
The thing worked well the several times I fished with him
cyclops2
Banned
Thank you for telling me something I have never seen or used.
It seems like a faster & easier way of bringing on board a heavy anchor with no power lifting available. :)
Rich
Fireman431
BTW, I forgot to mention, just let it hang inside the boat from the ring on the bowrail at the very fore of the boat, at least that's where I've always seen/kept them.
cyclops2
Banned
Now that I understand it.
Why not just use a good sized threaded ring like climbers use and a small mooring ball. Take it on & off as weather dictates. A boathook gets it onto a rubber or Nylon mat on the deck to remove the ball.
DuckHunterJon
Huh, learn something new every day. Thanks for the video link!
mr 88
She is in the kitchen,eating.....................
jacoboregon
I live now in Oregon, and see them used extensively among the guides on the Umpqua river and the Columbia. Most I've seen have a quick connect between the float and the anchor rope sleeve so it can be removed for storage in the boat. They also have a quick link to the bow eye so they can quickly disconnect and leave the anchor/buoy in the water if they need to chase a fish that's on line, then can come back to retrieve the anchor.
Btw, they are absolutely the best for retrieving an anchor in anything over 15' of water! Very quick and easy!
