I spent most of my day fishing today and worring about the tell-tale not putting out much of a stream like it normally does. Just a sputter/dribble. I actually pulled the hose loose from the cowling freeing up the end of it and poking .80 nylon trimmer material in it several times. It would still just dribble. Not something I like doing while fishing in a strong tide flow. (I did have a fishing buddy with me), otherwise I would not be hanging over the back of the boat. I kept putting my hand under the tell-tale water to see if it was hot and it was not, only maybe 100 degrees, so I kept fishing. (not catching) When I got back into the harbor at the wash down, I used (80# water pressure) a hose with a spray nozzle and forced water into the tubing for the tell-tale until I had a a good flow of water going thru the engine and out the exhaust. I then fired it up with the hose disconnected from the cowling and it sprayed water out 4 feet or so with really a strong stream. I have said all that to preface this question. Since the tell-tale come off the lower left side(facing the rear of the engine) of the block at the bottom, down from the thermostat housing. Does the tell-tale water come through the block or just routed through the plate to the bottom?
I had thought about pulling the thermostat out, but I did not think that would have changed anything. Can someone explain the water flow to me.
