Tell tale pumps water at idle, but not under power. Is this OK?
John692696
I have 1988 85hp Force outboard. It is running fine. But I have notice that the tell tale is pumping water at idle and 1/4 throttle, but as I increase the throttle, the water slows downs and then stops. I have replaced the impeller and flushed the system, but it has not made much difference. What should I test or replace now.<br />Thanks<br />John
Walker
Re: Tell tale pumps water at idle, but not under power. Is this OK?
Sounds like the keyway is not holding the impellor on the shaft.
sloopy
have you tried running around for a cople of minues?!?!? that helps sometimes the motor is still COOOOOLLLL and the thermostat stays open or closed :)
