ccustomrides
- Mar 3, 2010
- 70
I have a 1990 4.3 Mercruiser.
I dont know if my gauges are just getting old but here is what i got.
My temp gauge reads normal. I mean once warmed up it will read 150F and I even checked it with a heat gun.
Problem is when I turn the key off it wont reset. Before I would turn they key off and my temp gauge would slowly drop back to zero. Now it will read the same temp unless I restart the engine and it will read cooler temp or if I cycle the key from acc to off and it will drop the reading when its cooling down.
So is this normal or is there something wrong with wiring or gauge. I did take the wiring off for the temp sensor when I repalced the thermostat last spring.
