temp gauge
MercBlackMax1
Hey does the temp guage usually connect to the inside or the outside ouf the block on a merc black max 200??
when i plug it up to the outside i get a reading on my gauge with the key on
when i plug it to the inside of the block i get a reading with the key off
Faztbullet
Re: temp gauge
Is it a OEM gauge or aftermarket??? Which sender do you have on the heads?? It will use the tan with blue stripe wire and must have the a screw in sender.
aussieflash
Re: temp gauge
Inside head sender is set to 240 deg and 15 1/2"wire lead.outside 190 deg.and 18 1/2"wire lead.
