temp guage
sikz3
My temp guage does not work any tips on trackind down why?
Don S
Re: temp guage
With the ignition switch on, make sure you have power to the purple wire, and good ground (Black wire) if those 2 are ok, at the sender on the engine remove the wire from the sender and hold to a good ground. With the switch in the run position and the sender wire grounded, the gauge should peg full hot.<br />If it doesn't, the gauge or the wire from the sender to the gauge is bad. If it does peg, replace the sender.
sikz3
Re: temp guage
Originally posted by Don S:<br /> With the ignition switch on, make sure you have power to the purple wire, and good ground (Black wire) if those 2 are ok, at the sender on the engine remove the wire from the sender and hold to a good ground. With the switch in the run position and the sender wire grounded, the gauge should peg full hot.<br />If it doesn't, the gauge or the wire from the sender to the gauge is bad. If it does peg, replace the sender.
sikz3
Re: temp guage
So take the purple wire and ground it out to the ground to check?
sikz3
Re: temp guage
sikz3
Re: temp guage
sikz3
Re: temp guage
sikz3
Re: temp guage
I/O WALDO
Re: temp guage
NO! The purple is the key-on power wire!Don S means to ground the sender wire at the engine,knott at the gauge!
Re: temp guage
Ooopppssss,...... Misread That 1......
sikz3
Re: temp guage
so there is only one wire at the sender? And jump that wire to a ground? Thanks. Haven't got a chance to get in there and check it out
