Was watching my temp gauge while running my motor in the driveway and noted it went from 145 degrees all the way to the left. It hasn't moved since. Saw a great tip here and removed the wire at thermostat housing and touched ground and temp gauge needle moved all the way to right. Did this once. Removed sensor/sending unit fom housing and cleaned it up. Appears to be all brass. Reinstalled and nothing.
So, my question is, do these units go bad? I did not clean up threads inside of housing.
Thanks for considering.
