Re: Temperature Alarm is Sounding
If there is sand in the thermostat housing, it may be elsewhere in the engine. I'd pull the head covers off and see if they are also filled with sand. If you find sand there, pull the heads and check the water passages aroung the cylinder liners and check your water diverters. You may need to pull the inspection cover off the top of the block and look for sand down inside between the cylinder banks. Sand will also abrade/damage the rubber impeller, so you may want to follow boobie's advice.
