temperature gauge fault
Big Reidy
My temperature gauge spikes and stays up when ignition switched on. Is this a faulty gauge, or could it be something else?
alldodge
Could be the gauge or the sender
Make sure your getting 12V at the gauge when key is ON.
Check for a good ground from the gauge using an ohm meter to ground
If those check good, remove the sender and place in a pan of water on the stove with an ohm meter connected to it, and a water temp probe in the water
Should read 240 ohms cold and 33 ohms above 210 degrees
wellcraft-classic210
Master Chief Petty Officer
1 added comment
If the wire going from your gauge to the sender unit ( temp sensor ) on the engine is shorted to ground it will cause the gauge to read high also.
Good to know this for gauge trouble shooting also.
