Re: Temperature Gauge Outboard
The next question is do you have the temp sender and what type is it. Threaded or contact type? If it is the threaded type it can be screwed into any port that puts the tip of the sender in the water jacket. Or it can be screwed into the optional "Z" bracket and attached to the cylinder head with a head bolt (which technically makes it a cylinder head temp gauge). Or you could use the contact type that also bolts onto the head via a head bolt. If this is all new stuff, it should have come with instructions. If you didn't get any, contact the supplier of the sender and gauge.
