Temperature Gauge Troubleshooting
Bulbash
OMC 2.3 Cobra setup. Started up and ran perfect first time this season, the only problem is that the temperature gauge doesn't seem to be working. I will try to install a new thermostat but I'm more suspicious of the gauge having an issue. Where would you start to troubleshoot it.
Ayuh,.... Check to see if there's power to the (+) terminal on the back of the gauge,.....
At the Sender, remove the wire, 'n ground it out to a known good ground,...
The gauge should Peg hot,....
With a jumper wire, test to see that the senders base is a solid ground,...
If the gauge pegs, the sender is bad, if it don't, it's probably the gauge,....
gm280
OR the wire from the sender to the gauge as well.........
Bulbash
Found it. Seems like gauge and sender are working. Must be a thermostat issue.... Not warming up. staying cold...
Bulbash
I am thinking that I could place thermostat the wrong way in... Does anyone remember if the spring has to face the manifold or not?
