Last year our 07 3.0 Merc with 115 hrs ran a tad warmer than I remember it running (175 on the hose, slightly higher in the water) used to be 150 on the gauge while on the hose and around the 165-170 at W.O.T.
Now that its time to put it in the water I just put a new Quick silver t stat in and its still at the 175 on the hose. When I IR temp the block it shows in the upper 150s low 160s on the hose (where the gauge used to read)
Sound like a bad gauge or sender?
I just ordered a new exhaust elbow for it. The on that is on is original (brackish water use) it does not look too bad inside but the gasket surface is chewed up and it will not seal now. Exhaust Manifold is also original.
All the gauges are OEM installed Faria and over the last 2 season some have started to go "wonky"
Volt meter has entirely failed
Tach sticks once in a while
and trim erratically reads (but I did order a new trim roter if I ever get it Merc has it on back order until end of July)
I'm thinking of ordering an entire new set if that many are starting to fail rather then do it piece meal.
