Temperature sensor
tinkma
We found this (what I believe is a temperature sensor) just sitting on the bottom of the motor near the bottom of the carb. Where is it suppose to go? Thank you.
cyclops222
Is it the bad one ?
Make / model / serial number of motor ? Any NOT CONNECTED wire around ?
tinkma
Thank you for the help. It is a 2002 Evinrude ficht. 250hp I don't see any not connected wire around.
Crosbyman
could be just the air temp sensor fell out of position....it must fit on a clip or held by a bolt
