SvenVerheesen
- May 6, 2019
- 9
Hello everybody,
I have a 1990 Four Winns 180 with an OMC V6 4.3l engine.
I am upgrading/repairing the electrical wiring within the boat. All gauges are working again except the tachometer. I noticed that when the ignition is switched on that the needle will go to 0. This is an indication to me that there is still something working in the meter. But no output when the engine is running. I do not have equipment to measure whether there is a signal from the "-" side of the ignition coil so i want to bench test if the tachometer still works. Does anyone know how the signal have to look like that the tachometer needs? Or how i can bench test the tachometer?
Thank you in advance!
Sven Verheesen
Sven Verheesen
