Re: test coils
if your stator, trigger and switch boxes still work/check out and no spark on the spark plug thats the only way I see to check it. the book only shows checking those items listed above if you have an ohm meter you could probably compare them to each other unplugged it is nothing but a coil of wire inside that bumps the spark up.
