Test Drive Disaster
sje0123
Went w/ my father today to test drive his first boat. It's a used Bayliner Sierra 2355 (I think). I wasn't fond of it in the first place because:
It's a 1994
Reman Jasper Engine w/ only 226hrs on boat
Had a leaking linkage
etc
The owner took my Dad out a week ago for a ride and couldn't get on plane because of the leak. He had it repaired and we went today for a sea trial. He decided to bring a surveyor.
The hull was all banged up from hitting things. Nothing too bad. Mostly cosmetic, but at this point I wasn't happy as it was obvious they PO's hadn't spent much time caring for it.
After a dry look over we splashed it. The owner didn't want to come bacuse he was afraid he'd get sea sick because it was windy. How do you own a boat and can't go out on a mildly windy day??:confused: Either way, I was nominated to drive as I have boating experience and my father sat behind me. The owner shoved us off right into the bottom of the ramp. I tried to turn it but BAM! right into the bottom of the ramp.:facepalm: Checked the prop and all and it made it thru just fine. Got it out on the water and it was running OK. We started to come back in and dropped to low RPM in a limited area and the engine just died. Would not turn over, nothing. I managed to finally get it running and it would not stay running. I essentially had to rev the motor and slam it into gear so it didn't die out. I got fed up and turned the controls over the the surveyor to see if he could baby it in. He just nosed it toward the dock and floored it. We came in pretty hot but that's all we could do. Slammed the dock pretty good but no damage to the boat. Got off, called the survey quits, and walked away.
What a frickin mess. That's why you should always do a sea trial LOL.
tpenfield
Re: Test Drive Disaster
Great experience, thanks for sharing.
All too often we hear about people who actually bought a boat like the one you trialed. I'm glad to see that it did not happen in this case.
sje0123
It was truely an experience that's for sure. I just couldn't believe it. There we were dead in the water with a good 15-20 knot wind blowing us toward shore. I'm sure many of you know how difficult it is to navigate in wind. Add in a motor that will only run full throttle or nothing and docking is not a fun or easy task.
Its unfortunate because my Dad has been set on owning a boat all his life. He's still on the hunt and hasn't been discouraged. Just a little more careful in his selection. The surveyor was great. He cut the price down to 1/3 the normal cost due to the situation.
I'm just very glad the bugs came out before the check was written. Boat was about $5000 overpriced as it was.
j_martin
That wasn't a disaster. The disaster was avoided.
There's plenty of good boats for sale. Keep looking.
dave11
I couldn.t agree more. That is what sea trials are for.
KDAVID1
+1. And thanks for the original post--I defiantly know what to do now before I buy a used boat.
86 century
Ensign
Thats not to bad the 90 supra I just picked up has a new prop, strut, and prop shaft from a seatrial that went real wrong in total $1890. This is the story I got from the po. Needless to say they would not let me have the helm till we were in the midle of the lake.
Id would say you did ok with less the ideal weather and a rig that wont run.
Good luck and happy hunting
kenmyfam
Nothing worse than buying a nightmare.
No trial = no sale for me unless I would be paying "scrap value" for the equipment in the first place.
Just my 2 cents though.
