test halleffect
sonofjohn
87 4.3 ser # ob825796 205 hp 262cid thunderbolt iv 4bbl . tested hall effect per. boatfix.com. iget 12 volts but when i break the field with cardboard or afeeler gauge i still read 12 volts.shot? oram i doing something wrong. also mygear on the dist. looks like its worn tothe point where it is real sharp and ready to start to break teeth. iwill be buying a new gear.
Don S
Re: test halleffect
Have no clue what test you performed. Was this on the ignition sensor?
Lets look at your distributor first, while the gear may be worn, I would have to ask WHY. I would bet the bushings in the distributor are worn out. Pull the distributor and move the shaft back and forth. In one spot I bet you find there is a lot of movement. This would wear the gear, and allow the sensor wheel to contact the sensor (and kill it). You may need a new distributor, not just a gear. And what do you think the gear on the cam looks like?
sonofjohn
Re: test halleffect
Don S
Re: test halleffect
OK, so you can quote what I said, but what does that mean? ? ? ? ? ? ?
sonofjohn
Re: test halleffect
hey don. the new long block hasnt arrived yet.im going through all components to install in new eng.i bought the boat with a busted block from not winterizing it right. gota deal!lookin at dist. it was a little rusty under cap. i connected 12v to ign. sensor then measured output volts.itwas 12.then i inserted feeeler gauge between magnet and sensor. shouldnt the voltage vary from zero and 12 volts.
Don S
Re: test halleffect
That's not how you test it, and you probably fried the sensor. It doesn't hook directly to a 12V source and ground. It connects to the ignition thru the ignition amplifier.
Can you say Mercruiser service manual?
