test trim cylinders possible?
boatdude100
I dont want to fry a new trim motor assembly if the trim cylinders are siezed or something. Chan these be tested?
SX-A Trim just suddenly stopped working
Doubt it's siezed
Yes you can test any hydraulic cylinder
Most likely electrical issue preventing the pump from running
boatdude100
Doubt it's siezed
May I ask the process of testing the hydraulic cylinder?
You are likely right- its probably electrical however if it is seized and I fry another trim motor... well best quote I have so far is close to $2000 CDN for the part! Better safe than sorry
dingbat
Crack a fitting on the cylinder or the fitting on the supply going to the lower fitting.........cylinder will move
Horigan
The motor has pressure relief valves in both the directions, so you won't damage the motor with a seized ram. You hear them open (change in pump tone) when you trim the drive against the stops.
