Re: Testing carbs?
WHAT is in bad shape, tells us nothing.
the way you make sure a cylinder is "running", is to pull the plug wire, off when the motor is running. when the wire is removed, the RPMs should drop, and resume normal operation, when replaced.
if this does not happen, you have 3 possibilities. no fuel/oil getting to cylinder, bad spark ( could be plug, plug wire, coil), last is low compression.
