I'm considering purchasing a 9.5 hp Evinrude Sportwin. The model number is 9322B, and the serial number is J 07865. These iboats forums have been a GREAT help in getting me up to speed on outboards, so THANKS!!<br /><br />I plan to do a compression test before buying the engine. I've heard that, at least for some engines, it can be bad to have the spark plug leads disconnected from the plugs while cranking the engine (pull starting in this case).<br /><br />1. Will it hurt the ignition system on this engine if I just remove the leads and plugs, go to WOT, and perform the test?<br /><br />2. Even if it doesn't hurt this particular engine, does it indeed cause damage on other types of engines, and what class of engines are those (e.g., electronic ignition, electric starte, etc.)? What kind of damage? Or is this just a myth?<br /><br />3. I'm guessing that a '73 doesn't have a dead man's switch/lanyard. If not, how else could I disable the ignition system to prevent harm, if that is an issue?<br /><br />4. When people refer to "grounding" the spark plug leads, does this mean you can ground the lead itself directly to the block, or do you need to do it through the spark plug, or does it matter?<br /><br />5. I've heard that I should look for 5 - 10% max difference between cylinders. Any guidelines on min psi values? Does the fact that it is a pull start, vice electric start, affect the values? <br /><br />THANKS
