Fiat4Fun
- Sep 14, 2009
- 223
Greetings,
I have an old 1986 Chris Craft Scorpion that has about 700 hours on it, with a 260 mercruiser and alpha one. At the end of the season last year, when the boat was getting the it's winter service, my mechanic noticed a bit of water under the middle of the boat. He thought maybe the hull had a leak, and we have had some little bit of water in the bilge over the season during our outings. Nothing too bad, but the bilge pump would come on. Mechanic was not sure where it was coming from.... So, now that's it is time to think about going boating, I went looking for the leak. I put the plug in added some water to the bilge under the motor, and lifted the front end up, let it sit for a while, no leaks on the floor. Lowered the front end, and let it sit, and still nothing on the floor. Wondering if there could be a leak on the side, that would not let water out from the center when I put water in the bilge, but water getting in from the side of the hull, and then leaking down through the stringers, and into the bilge under the motor? I am was thinking in the area where the runners on the trailer sit up against the hull?
Anyway to check this? Or is it just a visual inspection, and patch any area that looks thin???
Any advice would be appreciated.
Thanks
Thanks
