Testing oil alarms?
rkersh409
I have a 1995 Evinrude 175hp with the VRO2 pump (4 wires). I was wanting to test my alarms to make sure that they are working properly. I first grounded my temp sensor and the warning buzzer went off. Then I pulled the oil pump out of the oil tank and turned the key on but got nothing except for the alarm when you first turn the key on. Am I not doing something correct? I though by pulling it out of the tank it should give a low/no alarm.
Texasmark
Re: Testing oil alarms?
The initial beep is supposed to tell you that the system is ok.
I had a Merc with a separate tank for oil and to activate that alarm you had to turn the tank upside down.
I am a mechanism guy; want to understand how things work, then I know what to look for when trying to fixem. So I try to learn how things work.
But, I am not familiar with the workings of oil alarms so I don't know what it takes to activate; but you would think if you took it out of the tank, it would be analagous to an empty tank and you'd think it's set off the beeper.
Just a minute, I'll see if my Merc service manual has some info.
It says (Merc) to test the sensor you disconnect both leads going to the sensor and if the tank is empty you should have continuity between the wires.
Mine is an engine mounted tank and not OMC so yours may be different.
So, other than having something funny in the tank like a stuck float or something, you should be able to measure your sensor in the same position as it is when installed...like what's up needs to be up.
Since it mentions float position, there may be a button on the sensor that you have to depress to simulate the condition when the float is at the bottom of the (empty) tank.
Then to test the rest of the circuit, turn your ign on and take a piece of wire and short across the wires in the harness that go to the sensor; the horn should come on.
Best I can do.
Mark
rickdb1boat
With the tank empty, you should get an alarm. 1/2 second alarm every 20 seconds...
rkersh409
I understand that I should get the 1/2 second alarm every 20 seconds. And with my oil pump compleatly out of the tank shouldn't I be getting the alarm? The pump doen't have a float on it. The only thing I can see is a little metal shaft going through the pump with a little washer type thing on the top. The shaft moves up and down but when I push it all the way down I still dont get the alarm. Am I doing something wrong to test the system? And why am I getting a faint ticking sound from my controls? Sounds like a clock but faster. And I dont have a hour meter.
jtexas
the ticking sound...does that happen when you try to trip the oil alarm or all the time...could it be the sound of a buzzer trying to buzz but can't for some reason, like really low voltage maybe...
