1986 Merc. 175<br />I've done a search on this topic and have found some information...<br /><br />My question is, does anyone have a detailed process for testing the stator/switchboxes?<br />I'm aware of needing a peak reading DC voltmeter. <br /><br />I believe the readings should be such:<br />Blue wires to switch boxes..200+ volts....red wires...anything over 20 volts...output to coils...180 minimum....these tests done at cranking speed using a peak reading DC voltmeter....regular dc meter will get cooked.<br />(this from a previous post)<br /><br />Does cranking speed mean while the engine is at idle only?<br />My reason behind testing is I believe I have week spark on 1,3,5 cylinders... Engine will not idle and runs horribly.
