Testing Stator & Rectifier
Hardcore
Can i test the stator and rectifier on a 1992 evinrude 140 looper without removing the flywheel? and also how because my manual doesn't say anything about either. ANy help much appreciated. thanks in advance.
Vic.S
Re: Testing Stator & Rectifier
The small non regulated rectifiers can be tested by following Joe Reeves' instructions on the Engine FAQs board but I know of no way of easily testing the regulated ones as fitted to a 140 looper.
The stator coil could be tested for continuity. It'll have a fairly low resistance but you wont detect shorted turns. The AC output going to the rectifier (yellow wires) could be checked. Can't quote a figure but you should get well over 12volts once the revs are increased.
daselbee
I posted a lengthy answer in your other thread. Why are you double posting?
I posted very early in the morning, Friday, and I cannot understand why you would not read your other answers first, before posting again this afternoon????!!!!:mad::(
