that pretty much says it all ive got an oil injection system and i dont trust it, can i just run 50:1 mix for a little while and monitor the oil level? is there a way to know if its absolutely getting the right mix? do the injection pumps go bad? my service manual says i should change the check valve between the fuel and the oil filters every season?would that be a good idea? - the motors been sitting for 6 years
i cleaned out the check valve and everything seems to be working on it
also manual say i can purge the oil system is there a good way to do this?
i took all the hoses off and cleaned them and the filters
thanks
-Levi
thanks
-Levi
