thank you and more
doubledtrucker
Double d here would like to thank everyone for the information and help to the questions I have had this site is great again thank you. I was told one problem could the stator how do you check it?
HighTrim
Re: thank you and more
I am unsure of which model outboard you are referring to, so the specs may differ. Disconnect the yellow lead and yellow/gray lead at the terminal block. Connect the red meter lead to either yellow lead and meter black lead to ground to check for shorts. An infinite reading on HI ohms scale indicates the windings are good. Connect the ohmmeter on LO ohms scale between the yellow and yellow/gray. A reading of .25 ohms + or - .1 indicates the windings are good, and an infinite reading indicates the windings are open. If windings are found to have failed, the stator must be replaced.
