The difference between these 2 harnesses ?
hadora
What is the difference between these harnesses ? 84-879978T1 and 84-879978A1,
i want to install 2 SC1000 smartcraft gauge but i can't figure out the one i need for the speedometer
Thanks
Fun Times
Re: The difference between these 2 harnesses ?
FYI, 84-879978T1 has superseded to 84-879978T11, and 84-879978A1 comes up as customer cannot buy from mercruiser.:facepalm: But googling the numbers seems to be the length for the difference. Also from what I can tell part number 84-879978A1 seems to come in a kit vs ordering one by itself.
http://www.mercurymarine.com/_media...ft_manuals/System_Sped_Tach_Install_Sheet.pdf
We are selling a NEW, in the bag, wiring harness for Smartcraft speedometers, Mercury part number 84-879978T1. Includes instruction / installation manual.
Manufacturer: Mercury
Mercury part #84-879978T1
Vendor: Tracker Boats
Measurement: 15 Ft 6 In.? ( Note) I seen in a book the length should be 3 m (10 ft.) 84-879979T1.:facepalm:
Connections: 9-pin 5-pin female
http://greatlakesskipper.com/produc...rtcraft-boat-gauge-speedo-wiring-harness.html
We are selling a NEW, out of the bag, wiring harness for Smartcraft gauges, Mercury part number 84-879978T11. This wiring harness is for a Smartcraft speedometer and has a tag which reads: part number 8M0031689 Rev C Cable Assembly Speedometer. Includes instructions.
Mercury part #84-879978T11
Length: 5.5 Ft
http://www.ebay.com/itm/MERCURY-84-...s=63&clkid=1542593915688124066&_qi=RTM1062687
8M0031689,
http://www.ebay.com/itm/MERCURY-8M0..._Accessories_Gear&hash=item2eb130dcfc&vxp=mtr
Not much info found with this number 84-879978A1 except like said, it appears it's supposed to come in a kit, not individually.
http://www.ebay.com/itm/MERCURY-SMA...738882&pt=Boat_Parts_Accessories_Gear&vxp=mtr
You may be better off to just call mercury marine.:D
Sorry i can't be of better help.:( Good luck.
