THE MATRIX EFFECT
Calfasaur
Hi all i have a small problem. I got me a Mercruiser 4.3l V6 1989, Went for a spin on my own went fine. Could of maybe gone a little faster, but the you go :rolleyes: however when my family joined in the fun the boat would have gone faster if we turned the engine off and paddled with our feet :eek: anyone think of any problems that it might be :confused: It has all new plugs just serviced timing fine idles fine, please help :D
vipzach
Re: THE MATRIX EFFECT
We need more details!!!! WOT, how high would the rpm's go, what prop, things like that!
Calfasaur
With just me in the boat it ranged from about 2500-2800rpm with everyone else in 2000-2500rpm. Not sure of the prop. Engine sounds fine just seems to lack power :confused: If the boat is in neutral it revs a goodn. Put load on to the leg power seems to fade.
Hunt
Presure test the cylinders. ( my uneducated guess would be rings or valves ), Probably could be as simple as bad gas. These guys are great and I am sure they will give more expert advise than mine.
vipzach
Has the boat had a good tune up lately? New plugs, wires, cap/rotor or points, filters, checked timing, compression test maybe needed.
Calfasaur
yep all the above apart from compression. If it is compression would the not be signs of chugging or some thing? Exhaust is fine no dark smoke or smell of burning oil, the plugs that i relpace seemed fine.
vipzach
Is this a new to you boat, has it ever reached WOT, because 2800 is too low. Look at the prop and see what size it is.
Calfasaur
Yep new boat to me, came with a pair of spare props that seem the same size. What would be a recommended size? WOT? wot this?<br />cheers
Alumarine
WOT means wide open throttle.<br />Boats should be able to obtain a certain rev range with the correct prop.<br />Props often look the same but aren't.<br />They should have a number on the hub indicating size and pitch.<br />Someone might be able to help but need to know the size,type and maybe weight of boat.
vipzach
WOT is probly around 4400-4800, what size of boat is it?
Calfasaur
Its a 19'6 Elan Invader 1 1/2 tons? there about, just had a look at the spare props they are - 48 78122 A40 21 and 48 78118 A40L 17P not check on the boat yet though with the boat in neutral it will attain 4400-4800rpm no problem again all sounds fine no smoke or stange noises (sounds quite meaty actually)<br />P.S thanks for all your input
vipzach
calfsasaur, try that last prop that you have listed, the 17p.
Alumarine
yep, try the 17 and<br />please don't rev it so high in neutral
Calfasaur
Will check to see whats on the boat then see what happens. Well time for bed will revert soon many thanks for all your suggestions. Cheers C
Wotknot
If you rev it up in neutral to 4800 rpm, you're going to have more trouble than just too low rpm's.
Alumarine
Another thing, if the 17 is too small you may over rev it in gear.<br />Don't exceed 4800 rpm.
