f_inscreenname
- Aug 23, 2001
- 2,591
I am in the process of installing a 454 to my Volvo 280T in place of my Mopar 360 that was in the boat before. I am having a issue getting the thing lined up. When I first tried to install the 454 motor I found out that I needed to raise the motor mounts blocks (what the 454 mounts sit on in the boat) by almost 2 to match the height of the Mopar. I did that and now the (with a little adjustment of the big motor mount bolts) bell housing fits perfectly in the transom shield. With that done it was time to line up the front of the motor. I did that buy checking the tabs on the bell housing to the transom shield. They are almost perfect in space apart on all sides but the motor looks crooked. If you look in the picture you can see the motor sits closer to the right stringer then it does to the left side. Is that normal or is there another way of doing it?
