The purpose of this hole is ?
Vandkanten
Anyone know the purpose of the hole close to the peehole. ?
Faztbullet
That circled in red is the water pump indicator and fresh water flushing attachment.
Vandkanten
Thank you. I have looked in my manual, and I cannot find anything on this hole.
Fresh water flushing attachment, whats the purpose of this?
Tassie 1
You put an adapter/attachment thingee into the hole and attach a garden hose,
the other end is connected to a garden type tap,
you then turn on said tap and water flows through the motor case flushing out salt "crystals " etc etc that may otherwise block the cooling passages in said motor,
it's part of normal maintenace,
you should try and find a operators handbook BEFORE running this outboard,
it will also tell you whether this particular motor needs to be running during the above operation,
some don't,
but l think it would be wise if you did it anyway,
Thank your mother for the rabbits,
Vandkanten
Thank you Tassie :) Now it makes senses.
I just looked at my manual, it was the service manual and not operator manual.
Tassie 1
No, don't thank me lol
faztbullet did the hard yards,
l just expanded on his good work,
