Thermostat fell out of housing
hckrphil
I pulled my thermostat housing and the thermostat had fallen out of it, and it was laying inside the intake directly below the housing. Lucky I checked it.... found the rubber o-ring too.
Any idea what would cause this? What can I do to prevent it in the future? The only thing keeping it in is that rubber oring.
Phil
jharvey1984
wrong thermostat perhaps. Not sure how that is possible. What engine? Pics?
bruceb58
If there is corrosion in the thermostat housing, it is possible the o-ring could not be installed deep enough into its slot.
hckrphil
The engine is a Volvo Penta 5.7GS....
This is what I bought.... looking at it now, it doesn't mention the GS model... hmmm
Kit Contains:
1 160 degree thermostat (Replaces OEM Part #: 3856961)
1 Gasket (Replaces OEM Part #: 3852111)
1 O-ring (Replaces OEM Part #: 3852071)
Fits the Following Volvo Applications:
4.3GL5.7GL
4.3GS5.7Gi
4.3Gi5.8FL
5.0FL5.8Fi
5.0Fi5.8FSi
BRICH1260
I would bet that you have corrosion in the O ring grove. You might take a small wire wheel brush and try to clean it out a bit.
Lou C
Yep that makes the most sense, unless whoever installed it last, did not make sure it got all the way in the groove. Usually its hard to get it OUT of that groove lol....
hckrphil
I just re-installed it..... seems pretty solid now in there...... we will see :)
