Thermostat help 93 40hp
sulfurburner
Hey Guys I'm in need of some help again. I've tried searching all over but can't seem to find a diagram for the thermostat on my motor. I was up till 11 last night finishing up the impeller/water pump kit install and didn't spend too much time looking before calling it a night, but I wanted to find something to reference before I got home and started in again. I usually use boats dot net or the like but for some reason the diagrams aren't loading for me today :confused:. Any help or advice you could give would be appreciated
motor: 93 evinrude tracker 40 hp TE40ELETB
sulfurburner
Re: Thermostat help 93 40hp
Thanks for the link! So I went home took the Tstat out and it looked good...except for the chunks of what appears to be old impeller behind it. Fearing the worst I left the Tstat out and started it for the first time with the new impeller hoping the pee stream had improved. Still the same dribble it was before. So I'm going to go ahead and assume given the chunks I found that there is blockage in the cooling passage somewhere, but I don't have a clue where to start. Is there any tricks to clearing a blockage or do I have to tear it apart?
